a/c heater question
Old Apr 22, 2009 | 07:38 PM
aic's Avatar
aic
a/c heater question
is it normal for my 90 f250 to bog down significantly when the heat or ac is on. I can see with the a/c but having the heater on clearly pulls down the engine. For some reason it seems the a/c compressor kicks on when the heater is turned on. Is this normal?
Old Apr 22, 2009 | 07:41 PM
Moore558's Avatar
Moore558
If you have the selector switch in mix or defrost it will kick the compressor on to blow dry hot air onto the windshield to help remove condensation.
jr32560's Avatar
jr32560
the ac does kick in when it's on bi level or heat/def-it removes the humidity from the air to clear the windshield faster
Old Apr 22, 2009 | 07:44 PM
aic's Avatar
aic
Thanks for the help, makes more sense now, much appreciated
