diff questions
Old Apr 22, 2009 | 03:36 PM
trugertha's Avatar
trugertha
diff questions
some one told me that i had 44 up front and 60 out back...i thought it was d50 ttb up front and either d60 or 10.25 sterling out back ...can someone set me straight??
Old Apr 22, 2009 | 04:46 PM
johnboggs21's Avatar
johnboggs21
im pretty sure it was a D60 or 10.25 out back, not sure on the front.
Old Apr 22, 2009 | 05:30 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
As I understand the easiest id for the front is:
If the Wheel Hub is the same size as the Locker it's a d44.
If the Wheel Hub is larger than the Locker it's a d50.
On the Rear the 10.25 cover looks kinda like a pear pointing to the right.
-Enjoy
fh : )_~
Old Apr 22, 2009 | 07:35 PM
starmilt's Avatar
starmilt
What truck are we talking about. Typically single cabs were d44 fronts extended cabs D50 the D60 is a solid axle unit not ttb.
Old Apr 22, 2009 | 08:42 PM
trugertha's Avatar
trugertha
haha sorry its a 91 7.3 ext'd 4x4
Old Apr 22, 2009 | 08:47 PM
joe f350's Avatar
joe f350
f250 of f350
Old Apr 22, 2009 | 08:56 PM
trugertha's Avatar
trugertha
its a 250 joe with code c5 4.10 limited slip i think and i believe its ttb d50 out front and 10.25 in the rear?
Old Apr 22, 2009 | 09:08 PM
joe f350's Avatar
joe f350
ya that sounds right
Old Apr 23, 2009 | 12:13 AM
trugertha's Avatar
trugertha
thanks for the info everyone
Old Apr 23, 2009 | 06:48 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Technically I think it's a 4:11, as if it really matters.
Old Apr 23, 2009 | 10:50 AM
Dean88's Avatar
Dean88
It could also be a D70 out back for some years. I was told that for a few years sterling couldn't keep up because of some disaster, and then they had a plant strike sometime later, so Dana filled the gap with D60's, D61's and D70's.
Old Apr 23, 2009 | 11:24 AM
trugertha's Avatar
trugertha
oooooo thats sum info there do you know how id check, maybe a site with diff covers?
Old Apr 23, 2009 | 11:37 AM
Dean88's Avatar
Dean88
If its got a plug in the diff cover, then its a Dana. No plug = Sterling.
Old Apr 23, 2009 | 11:38 AM
Festus Hagen
Methanoholic
Axle Identification Chart
-Enjoy
fh : )_~
Old Apr 23, 2009 | 11:43 AM
Dean88's Avatar
Dean88
Dang you Festus, I was looking through all of my favorites for that exact page. Its a good chart, but I do have a few arguements with them.
Such as they call the Sterling 10.25 the biggest Ford rear end, but then what do they call the Ford 10.5 in the 99+ SD's?
They also forget the Dana 80 found in the late 90's Dodge's, along with the D61 that people need to warned against, plus they forget to mention that the D70 could be found in a Ford.
