351w help
Old Apr 22, 2009 | 12:10 PM
Beamed's Avatar
Beamed
351w help
so ive found a 351 short block but its a 79 block. the prob is my truck is a 94 could i still use this block whats different about them i still want to run the efi heres what the guy wrote me "It doesn't have the holes for the roller lifter spider in the lifter valley but if you want to run roller lifters you can use the retrofit link bar lifters. I think it has early style rods (69 I think) which puts the pistons a bit further in the hole but I was going to use aset of aluminum heads and still could get 9.5:1 compression. It is already bored .060" over" would i want a roller block thanks for any input
