Transfer case questions
Old Apr 22, 2009 | 11:34 AM
FourWheel's Avatar
FourWheel
so my transfer case is making a clunk when shifting forward to reverse and also sounds like a chain stretching when first starting off i drained the fluid and found some metal what do you think this could be also what kind of case is this what year trucks had this case in them. should i replace or rebuild any help would be greatly appreciated
Old Apr 22, 2009 | 12:06 PM
fkaster01's Avatar
fkaster01
i've heard the rebuild on these isn't too difficult to do at home, the metal parts found when draining is almost never a good thing and the stretching???? chain? I know there is a chain in the case but don't think you could hear it stretch, if so that is most certainly a bad thing. I would look into a rebuild as opposed to replacing. someone else should be able to shed some more light on that issue for you
Old Apr 22, 2009 | 12:10 PM
FourWheel's Avatar
FourWheel
Yeah its something that makes like a clicking noise when torque is applied i'm guessing the chain but could be bearing maybe?
