rough cold starts
Old Apr 22, 2009 | 11:13 AM
nflfreak43's Avatar
nflfreak43
rough cold starts
So in the past couple of weeks i've noticed in the mornings when i go out and start my truck if its been overnight it starts up and acts like its gonna die and then idles up. but this morning it did actually die. so i started it again and it was running like super rough till i revved it up. im thinking its the fuel filter. It's bout the most likely thing since the truck has almost 300,000 miles on it but the motor and tranny 74,xxx. but the fuel filter probably hasnt been changed in a long time. so whats your thoughts to what the problem is???? thanks for any ideas.
Old Apr 22, 2009 | 01:26 PM
HrdDrv's Avatar
HrdDrv
Fuel filter/tune-up, fuel additive/throttle-body clean out...A lil' tlc...
Old Apr 22, 2009 | 01:42 PM
nflfreak43's Avatar
nflfreak43
yeah the only thing that i havent done is fuel filter and throttle body clean out. but i think i need to do another tune up because i think a plug has somewhat foulded out. but yeah. basically i was thinking right.
Old Apr 22, 2009 | 01:52 PM
HrdDrv's Avatar
HrdDrv
READ the plugs when you pull 'em. That will tell you if you have a situation in a certain area. (Oil/carbon fouled, etc.)
Old Apr 22, 2009 | 02:10 PM
nflfreak43's Avatar
nflfreak43
it shouldnt be carbon fouled because every other fillup me and the previous owner would put in a fuel additive. And oil the motor uses absolutely !!ZERO!! oil. so i dont think its oil fouling. it maybe i need new plug wires. they probably need changing too.
Old Apr 22, 2009 | 02:51 PM
fkaster01's Avatar
fkaster01
faulty IAC may cause these issues too... try cleaning it out and seeing what happens, but still a good idea to change the fuel filter, I personally use Z-max additive in my truck every six thousand miles or so and have had good results with it, about forty bucks and comes with fuel and oil additive, good luck
Old Apr 23, 2009 | 12:27 PM
Muv's Avatar
Muv
dito on fkaster01.
I went thru this this winter, IAC was the problem. They get gunked up and stick. Try cleaning it. I ended up replacing mine (not cheap).
