6.9L oil issue
Old Apr 22, 2009 | 10:35 AM
florida250's Avatar
florida250
6.9L oil issue
Ive got an 85 6.9 f250 that hasnt been run for ages, and ive come up with the terrible idea to turn it into a buggy, yet the problem is that whenever we crank it up, it runs for several minutes, and begins spewwing oil from the filter, ALOT of oil, any help diagnosing would be appreciated, if more info is required, just ask.
Old Apr 22, 2009 | 10:57 AM
fonefiddy's Avatar
fonefiddy
Is prolly the oil cooler O-Rings.
Oil cooler disassembled
You'll want to install th O-Rings on the Tube, Before You insert it into the headers. It'll keep them from binding/cutting the O-Rings
Old Apr 22, 2009 | 01:19 PM
Dodge/Cummins's Avatar
Dodge/Cummins
The filter also has to be TIGHT or it will blow oil out around the lip seal.
I't probably won't be this easy but you never know.
