Proper operating temp
Old Apr 21, 2009 | 09:47 PM
nkapphahn's Avatar
nkapphahn
I posted this question on the 460 forum but havent gotten much of any responses. My temp gage runs at the very high end of the normal temp range so I used an infarred heat gun to check the temp at the water neck, radiator, and intake manifold where the temp sensor/sending unit is. The temp gun shows that the temps on the outside of these areas is 185-200 degrees. I dont know if using the heat gun is giving me an accurate temp or if the motor is in fact running too hot. Do I need to hook up a mechanichal temp gage to get a true reading or is my temp gage on the dash off (maybe its the unit from the 400 and reads different in the 460).
Old Apr 21, 2009 | 09:59 PM
califasbob's Avatar
califasbob
Are you saying you swapped from a 400 to a 460 and kept your original sender and gauge? I can't imagine they'd be different for the two applications.
Probably the bigger concern is how old that temp gauge is. Mechanical temp gauges are cheap from Summit or other parts houses, and while they may not be as reliable as more upscale units, they've got to be giving you better info than the cold/hot one in your dash. My old 351M with the factory gauge did the same thing on brutal Texas summer days in traffic (all the way into the H area), when I changed it to the (cheap) Summit gauge, similar driving habits produced temps of 235 or so. Not sure that helps. I'd recommend you splurge for an aftermarket gauge.
Bob
Old Apr 21, 2009 | 10:07 PM
Holiver31's Avatar
Holiver31
if it isnt the gauge check the thermostat,,if it isnt the thermostat check the sending unit,,flushing the cooling system would be a good idea to be sure all of your bases are covered
Old Apr 21, 2009 | 10:29 PM
fmc400's Avatar
fmc400
MSEE
Don't use infared heat guns to check coolant temperature, and don't base anything off the factory gauge. The only way to get an accurate reading is with a mechanical gauge, which places the transducer directly in the coolant path.
Old Apr 21, 2009 | 10:54 PM
shanes66charger's Avatar
shanes66charger
I guess I can say it ONE more time!
E-MANUEL GAUGES!
anything above 210-220 is getting plenty warm.
Old Apr 21, 2009 | 11:36 PM
fmc400's Avatar
fmc400
MSEE
Had a little bit to drink tonight?
Old Apr 22, 2009 | 10:05 PM
nkapphahn's Avatar
nkapphahn
Sounds like I need to go get a mechanicl temp gage. Thanks for the help.
