trailer brakes
Old Apr 21, 2009 | 09:15 PM
rockcrawler_101's Avatar
rockcrawler_101
trailer brakes
Im trying to wire up my trailer brakes and cant find the wire for the brake control. I found a plug that was just sitting there but it was dark blue while the wire in the back was light blue. This is on my 01 7.3
Old Apr 21, 2009 | 09:33 PM
danskool's Avatar
danskool
Go Bills !
Jammed way up under to the right behind the support frame. It looks like it is attached to the side of you heater controls driverside.. A bugger to get to. One of those plugs you can see but can't touch at the same time.
Old Apr 21, 2009 | 09:40 PM
rockcrawler_101
is it a plug with about 5 other wires attached to it?
Old Apr 21, 2009 | 09:44 PM
danskool's Avatar
danskool
Go Bills !
Here you go. Ran out to take a picture. Just a little forward of the grounding screws there is a hole through the support bracket. The plug is in the hole. Tough to get to and don't pull out far.. here is my controller plugged in..
