I don't know if the jets are interchangeable with Holley jets, but yes the 2100 uses a power valve. I think it's pointless to put a 2-barrel on a 300. A 4 barrel upgrade makes a lot more sense.
It doesn't. I meant 4 barrel carburetor and intake at the same time. A 2V-1V adapter plate is going to be so restrictive that you're not going to flow much more fuel and air in the first place, so you should upgrade to a 4 barrel intake. At that point you have the option of a 2 barrel or 4 barrel carburetor, but between the two a 4 barrel is much more efficient.
Im milling a flat on a stock cast 300 intake. Installing a 1 1/8" spacer Ill machine to accept a 2100 or holley 2BBL. I have time and tools so I make whatever I can.
There is not enough space to fit a 4bbl on there. If I had a digital camera Id show you what it looks like when its finished. This is a popular mod on falcon sixes and it gave me the idea.
Is the powervalve similar to a holley? If not are they still available in different rates?
