Sponsored by: Real Truck
o2 Sensors?
Old Apr 21, 2009 | 07:38 PM
hotrob's Avatar
hotrob
o2 Sensors?
I have an 01 F350 with the 5.4 liter. My problem is that the truck runs good while warming up, but when it gets to operating temp, it starts running rough. I don't get any check engine light. My research tells me that it is a bad o2 sensor. I found 2, one just below each exhaust manifold, and replaced both of those. I have read that there should be a least 3 sensors with one downstream of the catalytic converter, but I can't find one on the truck. Is this the case or can there be only two? After replacing the two I found the truck is still running rough when warm.
Could the problem be something else? All help is greatly appreciated.
Old Apr 21, 2009 | 08:45 PM
Monster-4's Avatar
Monster-4
There is no O2 sensor aft the cat. You'll just have the two on the y-pipe. 1999+ F250/F350 are over 8500 GVWR and or not required to be ODB II emission compliant. Basically they have ODB I system with an ODB II interface.
You may have a COP that is misfiring. If you have a scanner that reads pending codes hook it up and check for misfires.
Also clean the MAF sensor. Probably not it but doesn't hurt. Others will hopefully chime in with more ideas.
Old Apr 22, 2009 | 08:07 AM
ReAX's Avatar
ReAX
Yes, the coils can fail once warm but give little sign otherwise. You might try pulling each one and looking at the boots. Inspect them for color changes and cracks that could arc to the heads.
Closed loop glitches are usually o2 related, but it could also be a sticky IAC or EGR valve. Both can cause hesitation, but I am not sure about a miss.
Old Apr 22, 2009 | 09:10 AM
Bear River's Avatar
Bear River
Former ******
O2 sensors should be replaced at the most, every 80,000 miles. After that they can fail at random, and can also get stuck so you can't remove them.
grandpamuck
Feb 12, 2013 02:20 PM
MCGA
Modular V8 (4.6L, 5.4L)
Apr 4, 2012 01:23 PM
Schwinn240
13
Mar 25, 2010 06:57 PM
Vanhalem
3.8 & 4.2L V6
Apr 3, 2006 06:46 AM
