This line cracked on me because it was so corroded, I believe it was connected to the gas tank vents? What is the importance of hooking this back up or replacing it? It goes under the cab towards the motor, what might its purpose be
hey ford350baby can ya give me a shot from the other end?from the motor back towards the rear bumper? I might be able to help ya then!can ya see a connection on the other end?
**** its to dark now, but it goes on under the cab, and is on the passenger side outter frame rail and follows towards the front of the motor under the passenger side inner mud fender.
The vapor canister collects the gas fumes that come out when the temperature rises. Previously it just vented into the air and that was an environmental concern so they did something about it. I will also swear that I loose about 1L of gas per day when it's hot since mine is non functional.
Oh, so I should just hook it back up. Can I just use some gas rubber hose to replace it right?
That is the vent line to the charcoal canister. It is mounted directly below the battery. The charcoal canister collects the vapour fumes that is released from the tank by expansion as the tank warms up. A line is connected from the canister to the throttle body with a solenoid. The captured vapours are held in the canister until the computer opens the solenoid during part throttle and the vacuum of the intake pulls the vapours into the engine where it can be burnt off.
If you leave the vent on top of the tank open, you will have raw gas vapours released to the atmosphere, where it could pose a danger of catching fire. It's especially bad if the truck is parked in an enclosed area.
If you capped off the gas tank vent, it could cause the tank to form a vacuum as the gas is drawn out and starve the engine of gas.
The charcoal canister is an emissions control device. It needs to be connected properly.
I always wondered what that pack was under the battery, that makes sense. I highly doubt mine even works, it looks pretty beat up, and I think i remember removing it and it not having any kind of solenoid hooked up to it. I will have to further investigate this matter tomorrow now.
