Max Towing Capacity
Old Apr 21, 2009 | 05:45 PM
ggwash21's Avatar
ggwash21
Max Towing Capacity
What is the max tow capacity or where can i find it for a 2004 scab fx4 4x4 5.4l. Looking to buy a camper for work and wanna find out the limits
Old Apr 21, 2009 | 05:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Look in your manual or the specifications tab above.
Old Apr 21, 2009 | 06:18 PM
air1jpg's Avatar
air1jpg
It will depend on your axle ratio, bed length, cab, and engine size. There is a table in your owners manual.
Old Apr 25, 2009 | 08:30 AM
Roller150's Avatar
Roller150
If your truck has 3.73 with the other options you show above then 9200lbs is max from what Ford shows. I have pulled very close to this number and the truck did great. Taking off isnt the best but driving down the road it does a great job. I was pulling a 20ft heavy duty trailer with a bobcat on it that about 6800lbs and the trailer probably 2000lbs. Rule of thumb on trailers I have been told is go with the GVW of the trailer and as long as it doesnt go over the MAX towing of your truck you should be good with that trailer.
Old Apr 26, 2009 | 10:18 AM
jsoko's Avatar
jsoko
I have no problem with 6800#
slow starts, long stops
keep an eye on trans temp
stymie820
Jan 30, 2011 07:47 PM
TexasTrash
Jan 28, 2010 03:34 AM
Ultrastealth
2004 - 2008 F150
Feb 27, 2008 12:35 PM
mike330
Jan 24, 2007 08:08 PM
jbn
Aug 11, 2003 02:04 AM
