Sponsored by: Real Truck
No a/c
Old Apr 21, 2009 | 09:26 AM
JPETRO1051's Avatar
JPETRO1051
No a/c
2008 350 6.4 I have no power to the a/c compressor.Any ideas? I don't have a number of the fuse i need to go to.Any know problems with these?
I would like to check before i send it out for repair.
Old Apr 21, 2009 | 12:05 PM
WhëëlMå1's Avatar
WhëëlMå1
Moved to Super Duty
Old Apr 21, 2009 | 06:59 PM
dstig1's Avatar
dstig1
Fuse numbers are in the owners manual.
Not much to go on here. Could be anything from a bad AC selector switch, pressure switch, compressor clutch/field coil or the system has no freon due to a leak..or something just unplugged. You need to give a few more details for diagnosis. What EXACTLY does it do? Does the compressor clutch cycle every couple seconds? Blowing warm air? Does the compressor engage at all?
-Dave
Old Apr 21, 2009 | 08:43 PM
eightrac's Avatar
eightrac
There also a unit called a CCRM? or something like that. It is essentially a chassis relay panel and controls power to the compressor coil. Dont ask me where it is, I just know it exists.
