my '96 Ltd project
Old Apr 21, 2009 | 01:35 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
my '96 Ltd project
hey guys! so i have a '96 limited 4.0 4x4 which was my first truck and i've driven it daily untill almost a month ago when i bought a 2004 excursion.
recently its had some issues, head gasket went again, more tranny issues so i'm done with the V6 period. i have a V8 donor truck and i'm ready to rip into this project since i have a nice daily driver now.
heres some current pics
the rear bumper on there is off a '97 EB i'm customizing the stock bumper
so the plan is over the summer to swap in the 5.0/built tranny and rebuilt t-case. also swap out the torsion bars for the heavy B-rated bars and some lift rear springs. hopfully by this time next year it will be running with a 5.0 i'll update as things move along.
Old Apr 21, 2009 | 08:33 AM
marragtop's Avatar
marragtop
What year donor motor are you using? Keep in mind all the OBDII related components and wiring.
Old Apr 22, 2009 | 12:24 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
the donor is a '97 5.0 V8 AWD EB explorer that is only 3 months older of a build date then my '96 so it should go pretty well i'm hoping lol
Old Apr 22, 2009 | 04:51 PM
5.0B2's Avatar
5.0B2
You should be able to use the 5.0 ECM, plug the 5.0 engine harness and trans harness into your vehicle harness. Don't know about the AWD-think it needs the 5.0's GEM. If you can use your 96's transfer case you're probably better off - the AWD has no low range to my knowledge.
Old Apr 22, 2009 | 06:33 PM
liftnw8z's Avatar
liftnw8z
Pretty sweet looking ride there. I like the paint scheme...gives me future ideas for mine.
Old Apr 23, 2009 | 02:00 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
actuly the fully mechanical(sp) AWD t-case is the only easly installed t-case..i figured i'd keep that part stock plus i like how it handles in our other V8 AWD 5.0 explorers.
you can add a manual shift 4x t-case out of a f-150 but it takes some work and i'd rather have the AWD anyway.
