Start up problem
Old Apr 20, 2009 | 10:57 PM
Tralco's Avatar
Tralco
Start up problem
I bought a 81 F250 460 Automatic about a month ago and it starts fine 9 out of 10 times. When it fails to start I can hear the starter turning over but the engine does not, then I just turn the ignition switch again and it fires right up. Battery is new and charging system seems to be working fine. Is this because the starter is not engaging the flexplate?
Old Apr 20, 2009 | 11:04 PM
IreallyLikeFords's Avatar
IreallyLikeFords
Maybe the Bendix gear isn't engaging or maybe the flexplate has some worn teeth. I would take the starter out and look at the teeth on the flexplate.
Old Apr 21, 2009 | 12:17 AM
86bigred's Avatar
86bigred
sounds like the bendix to me as well.and while you have the starter check your flexplate to.better to be safe than sorry.
