dome light.....
Old Apr 20, 2009 | 09:50 PM
Q in Sac's Avatar
Q in Sac
dome light.....
Dome light is burned out. Need a bulb. Went to Kragen/O'Reily's they don't have it. Sylvanna doesn't list it. So, do you guys have an idea? please advise.
Old Apr 20, 2009 | 09:55 PM
Q in Sac's Avatar
Q in Sac
rear axle seal?
ABS light is on and brakes are "mushy". Pulled the rear drum off and it is soaked with "some fluid". Look a look at the wheel cylinder and it not leaking. From a brief advantage point. I know I must replace the shoes. But if the seal has failed how tough it is to repair? Tomorrow is will change the differential fliud. Need some direction(s). Hit me up.
Old Apr 20, 2009 | 10:58 PM
Moore558's Avatar
Moore558
Is that the bulb that looks like an old buss fuse?
Old Apr 20, 2009 | 11:17 PM
Q in Sac's Avatar
Q in Sac
Can't say. When I got it, the bulb was missing.. So I guess I'm stuck. Of course the Haynes manual doesn't have it. bummer. To the "stealership" I go.
Old Apr 21, 2009 | 07:25 AM
Jermafenser's Avatar
Jermafenser
It takes a 912 bulb.
