Carbs.
Old Apr 20, 2009 | 08:06 PM
SmallBlockV8's Avatar
SmallBlockV8
Carbs.
Will a Motocraft 2100 2barrel 400cfm carb from a 1971 f-100 with a 360 work on a 1982 f-250 with a 302 motor?
Old Apr 20, 2009 | 09:36 PM
Sycostang67's Avatar
Sycostang67
Yeah. And random letters to follow since I cant just give a simple reply.
Old Apr 21, 2009 | 12:10 AM
86bigred's Avatar
86bigred
you can have mine.once i get a new one, it's going to the scrap pile.
Old Apr 21, 2009 | 05:38 PM
SmallBlockV8
Carb.
Does it work good ,and how could I get it?
Old Apr 21, 2009 | 05:41 PM
SmallBlockV8
Carb.
So will it bolt up without any modifications?
Old Apr 21, 2009 | 07:04 PM
86bigred's Avatar
86bigred
should bolt up.was having carb issues last night.you wouldn't want mine.the high speed airbleed metering rods are sticking full open.i'm switching to ether a holley or edelbrock in a little while.
Old Apr 22, 2009 | 01:26 AM
Sycostang67
It should bolt to the manifold with no problems, it's little things like the linkage and choke you might have to play with. The gas pedal in a 71 is connected to the carb via a rod, while the 82 most likely has a cable. You can very easily go to a parts store though and pick up a ball stud to bolt to the carb linkage that would allow your cable to attach to it. The choke on the old carb may be thermal while the 82 had an electric choke. You may be able to swap the choke housings between the carbs or find one at a parts store.
