1997 F150 Speedometer
Old Oct 29, 2002 | 10:56 PM
dscheidt's Avatar
dscheidt
Post 1997 F150 Speedometer
I just bought a 1997 F-150. It is 2-wheel drive, reg. cab, long bed. It has a 4.6L V-8 with 4-speed automatic transmission. Can the speedometer be corrected by just replacing a gear somewhere? For instance, if I change tire size or gear ratio, I will need to correct my speedometer reading. Any help will be greatly appreciated. Thank you.
Old Nov 17, 2002 | 12:29 AM
kj308's Avatar
kj308
I'm attempting to calibrate the speedometer on my 99 F150, same engine and trans as yours. I bought a Truspeed calibration box made by Superlift. I got it from 4wheel parts wholesalers. I'm also having trouble installing it and have posted a message on this board looking for help. Hope the info helps.
Old Nov 17, 2002 | 09:29 AM
StrangeRanger's Avatar
StrangeRanger
Do you guys have mechanical or electronic odometer/speedometers? I know Ford used the electronic units in the early 90s and at some point switched back to mechanical drives. If your odometer is mechanical then you correct by changing the plastic driven gear at the end of the cable. If it is electronic, you correct it by reprogramming. There is a tech article on this subject in that section of this board. Either way you neither need nor want Superlift's aftermarket gizmo.
Old Nov 17, 2002 | 01:35 PM
steve83's Avatar
steve83
All '92-up F-series speedos are electronic. They run off the ABS sensor in the rear axle. Yours ('97-up) is calibrated thru the EEC by using an OBD-II scanner.
Old Nov 17, 2002 | 01:36 PM
steve83's Avatar
steve83
David8949
Jul 21, 2016 10:41 AM
Joey1997
Jun 8, 2016 03:22 PM
tfink3
1997 - 2003 F150
Dec 17, 2015 12:54 PM
kr514
Sep 24, 2015 10:22 AM
Jonnys.1991
Jan 15, 2015 12:37 PM
