Distributor drive gear
Old Apr 20, 2009 | 06:54 PM
austin2466's Avatar
austin2466
I am trying to run my 88 5.0. I switched the EFI for a carburetor and now have the old style distributor on my hands. Can I run that as is or do I need to buy a different gear, one similar to the one that was on the EFI distributor. The replacement is probably mid seventies or so. Thanks
Old Apr 20, 2009 | 07:28 PM
Conanski's Avatar
Conanski
Does the '88 motor have a roller or flat tappet cam? Probably easier if you tell me what the motor cam out of?
Old Apr 20, 2009 | 08:18 PM
austin2466's Avatar
austin2466
well its from 1988 mustang 5.0 im not sure which cam
Old Apr 21, 2009 | 11:33 AM
Conanski's Avatar
Conanski
OK, that motor has a roller cam so you need a steel distributor drive gear, you should be able to pull the gear of the EFI distributor and mount it on the old one.
Old Apr 21, 2009 | 05:05 PM
austin2466's Avatar
austin2466
Thanks Conanski.
