Sponsored by: Real Truck
5.4L Injector Service
Old Apr 20, 2009 | 12:18 PM
beeser's Avatar
beeser
The Ford dealer that I will be taking my 2004 F250 to suggested having my fuel injection system cleaned by pouring chemicals into the fuel rails and running the engine. Is this a good idea? Will it damage anything?
Old Apr 20, 2009 | 06:21 PM
mwsF250's Avatar
mwsF250
If you run only name brand top tier gasolines, really no need as they have good additive packages in them already.
If you regularly buy "unknown" fuels from whoever is cheapest, then it is worth considering every 50-100K miles or so - especially if you've noticed a decline in fuel economy.
It will not damage anything.
Old Apr 20, 2009 | 07:58 PM
ReAX's Avatar
ReAX
IT's probably a motorvac or Petro-chemicals mix and both are pretty decent. I can't see it doing any harm, and you might eek out a tiny bit of economy and performance with it.
I just run some seafoam through a vacuum line and some in the tank.
Old Apr 20, 2009 | 09:03 PM
carls 250's Avatar
carls 250
Find some one with a motor vac the cleaner is a soap product & it works great I've been using the machine for years & my customers love what it does.
Old Apr 20, 2009 | 09:36 PM
99f350sd's Avatar
99f350sd
I'm 52 years young I have never needed any such thing ever..They make great products like seafoam you put in your tank once every 2 years or so...Dealers are ripoffs..scams.
hate em...
Dick
Old Apr 21, 2009 | 12:28 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you don't have a problem, don't go fixing it
If you run good brand-name gas, don't worry about injector cleaning.
In my opinion, anyway.
Old Apr 21, 2009 | 01:22 PM
beeser's Avatar
beeser
Thanks for all of the responses. I decided not to have the fuel injection system cleaned and will instead use some of the gas treatments mentioned. The engine runs fine and it seems to make sense not to mess with it.
