Flywheel to pressure plate bolt pattern
Old Nov 21, 2002 | 08:46 AM
wiley0ne's Avatar
wiley0ne
Will a 10" clutch & pressure plate bolt to a 1986 flywheel?
Old Nov 21, 2002 | 07:54 PM
steve83's Avatar
steve83
[updated:LAST EDITED ON 21-Nov-02 AT 08:55 PM (EST)]If the '86 flywheel was drilled for a 10" clutch. Mine was drilled for both 10 & 11".
You'll probably get better responses if you mention the engine &/or vehicle...
Old Nov 22, 2002 | 12:47 PM
wiley0ne's Avatar
wiley0ne
The truck is a 1967 Ranchero that I'm installing a 88 302 that will develope approx 400hp. I'm using a 86 flywheel to hook up the close ratio 4 speed toploader. I have a Hays 10" pressure plate and clutch that I want to use. I'm wondering if this will work?
Old Nov 22, 2002 | 06:42 PM
MustangGT221's Avatar
MustangGT221
cadunkle
Nov 19, 2016 06:59 PM
NS70250
Apr 9, 2016 02:35 PM
HogginNboggin9
1983 - 2012 Ranger & B-Series
Oct 5, 2009 07:16 AM
Deadeye1963
Mar 3, 2009 10:16 PM
jackslater
May 10, 2005 11:01 PM
