maximum sustained rpm's
Old Apr 19, 2009 | 09:04 PM
notiones's Avatar
notiones
I've been putting a lot of highway miles on lately and have been afraid to take it above 2000 rpm's, which basically limits me to 70 mph. Not that I could sustain anything over 70 for too long as it would beat the sh#t out of me. It seems the motor is working pretty hard at 2K though. And I recently took on a 15% grade and I wouldn't let it go beyond 2K, which basically meant I was going about 20 mph when I reached the top. Having started at 65, I was not impressed. Could I have pushed it a little harder? Is 2000 rpm's about the maximum that should be sustained over a long period? This truck uses no oil, nor does it have any leaks (thus far anyway), and I would like to keep it that way.
Old Apr 19, 2009 | 09:09 PM
JethroF250's Avatar
JethroF250
i run 80 to 85 for hours on the highway. i suspect you aint got gauges yet but my pyro doesnt go over 800 at 75. you can run anything below 1200 degrees all day long. is your truck stock?
Old Apr 19, 2009 | 09:15 PM
KevinC.'s Avatar
KevinC.
Well I take it you have 3.55 gears with those #'s. For all those out there with 4.10's they are rumming around 2300-2400 rpm's at 70. Also on a 15% grade higher RPM's will keep your EGT's down so dont be afraid to push it harder. I wouldnt see a problem with running 23-2400 RPM's at all. With a boost gauge you can really tell how your engine is at cruising speeds. Around 1-2psi at 70 would be a perfect scenario, the less boost the less strain on the engine.
Old Apr 19, 2009 | 09:18 PM
JethroF250's Avatar
JethroF250
exactly. good guess lol. i run bout 2 psi and on a slight grade never go over 5. but i have also run at 2400 for a good while with no problems
Old Apr 19, 2009 | 09:20 PM
notiones's Avatar
notiones
No mods yet except the 6637 & ccv. Any other mods will have to wait until the gauges are installed, which seems to be taking more time than I thought. Primarily because I have been on the road a lot lately. It sounds like I should be able to push a little harder though, which is what I wanted to know.
Old Apr 19, 2009 | 09:27 PM
FARM69's Avatar
FARM69
Don't be afriad to run the engine harder. Under a load, your putting more stress on it than if you would crank it up to 2.5-3.5.
On those inclined grades it is essential that you keep the r's up to generate the boost to keep your egts down. Remember, you got a V8 under there and it needs to be rollin good to get the power. I wouldn't be afraid to run this engine at 3 1/2 k all day long.
Your lucky you have 3.55's... you can stretch er out quite a bit.
Old Apr 19, 2009 | 11:26 PM
pjwoolw's Avatar
pjwoolw
The 7.3 engine was built to spin at a good clip. My 6.9 purred like a Kitten at 2700 rpm. Lugging them is not a good thing.
Old Apr 19, 2009 | 11:30 PM
joe_13894's Avatar
joe_13894
Let it run up to 3000 RPM for hill climbing. For a little while those RPMs aren't going to hurt you.
Holding it down at 2000 RPM means you're only getting about 60% of the peak horses.
