Fluid Change Question
Old Nov 23, 2002 | 08:18 AM
MustangGT221's Avatar
MustangGT221
Okay, time to install my LS carrier in place of my open carrier. Now, I obviously plan on draining the fluid. I have 3 bottles of 80w-90 to go in and the extra is to lube the gears and bearing before they go in. I know I have to soak the clutches for atleast 15 minutes in friction modifier before they go in. When filling the axle back up, should I pour 1 bottle of 80w-90 in, then the 4oz of friction modifier, then fill the axle until it starts to come out the fill hole? Or is there another way i'm suppose to do it. Also, I'm going to clean out the housing the best I can since the pinion is still going to be there, what should I use to clean it out? Also, what should I use to clean the LS carrier going in? Should I clean the side and spyder gears that are going in too? They arn't DIRTY but still have lube residue on them. Thanks.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Nov 23, 2002 | 09:17 AM
steve83's Avatar
steve83
Mineral spirits - same as VarSol. You can get low-odor if you preferr.
Old Nov 23, 2002 | 10:10 AM
steve83's Avatar
steve83
