Cruise Control test help
Old Apr 19, 2009 | 07:39 PM
wcurtis's Avatar
wcurtis
I posted this in the super duty sections, maybe it should be here???
Mike Harrington posted this test a while back (Thanks Mike) see Below
My question is what & where is the speed control servo?? The only flash was when I started the test, the way I read this is the speed control servo defective
fficeffice" /><O></O>
<TABLE class=MsoNormalTable style="mso-cellspacing: 1.5pt" cellPadding=0 border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes" itxtvisited="1"><TD style="PADDING-RIGHT: 0.75pt; PADDING-LEFT: 0.75pt; BORDER-LEFT-COLOR: #f0f0f0; BORDER-BOTTOM-COLOR: #f0f0f0; PADDING-BOTTOM: 0.75pt; WIDTH: 100%; BORDER-TOP-COLOR: #f0f0f0; PADDING-TOP: 0.75pt; BACKGROUND-COLOR: transparent; BORDER-RIGHT-COLOR: #f0f0f0" vAlign=top width="100%" itxtvisited="1">Try this test:
Diagnosing/Resetting the Cruise-Control operations:
1. fully engage parking brake. Make sure <A href="https://www.ford-trucks.com/rx98192zju/kwldirect.php?kwid=396" target=_blank rel=nofollow>brake </A itxtvisited="1">peddle is released.
2. Begin static portion of self test by pressing and holding speed control off switch.
3. Turn ignition switch from off to run. The cruise indicator on the instrument cluster will flash once to indicate the speed control module has entered diagnostic mode.
If the cruise indicator does not flash repeat steps 1-3. If the cruise indicator still does not flash, diagnose the cruise indicator.
4. Release the off switch
5. The cruise indicator will flash when each switch is pressed. While performing self test. Press each switch in the order described while observing cruise indicator for a flash. Note any switch activations that does not cause a flash.
Within five seconds of turning the ignition switch to RUN:
Press the on switch.
Press the resume switch.
Press the coast switch.
Press the set/accel switch.
6. NOTE: the on switch must be pressed within five seconds after entering the diagnostics mode or the speed control module will return to normal operating state and self-test must be repeated.
Flash Code Function Tested Possible Cause
0 Speed Control Servo Speed Control Servo Defective
1 Complete System
2 Stop Light Switch Circuitry Stop Light Switch Circuitry
3 <A href="https://www.ford-trucks.com/rx98192zju/kwldirect.php?kwid=396" target=_blank rel=nofollow>Brake </A itxtvisited="1">Deactivation Circuitry Brake pressure control
valve defective circuitry
4 Vehicle speed sensor Vehicle Speed Sensor Out of
range
5 Speed Control Servo Speed Control servo defective<O></O>
</TD></TR></TBODY></TABLE>
__________________
2003 Ford F-250 S/D ffice:smarttags" /><ST1lace w:st="on"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comXLT</st1:City> <st1:State itxtvisited="1" w:st="on">SC</st1:State></ST1lace>, 4X4, 6.8 V10 Triton, 4.30 axles w/Gear Vendors overdrive. Firestone 265/75R16 Transforce HT. Pullrite 16k Super 5th hitch/2006 Cardinal 30LE WB
Mike Harrington <O></O> <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
__________________
2001 f250 SCAB 5.4 2WD LB
16 ft lowe bass bost
30ft aerolite travel trailer
Big Blue
http://s272.photobucket.com/albums/j...rucksmall2.jpg
<!-- / sig -->
<!-- controls -->
Old Apr 19, 2009 | 09:33 PM
Franklin2's Avatar
Franklin2
What truck are you working on?
Old Apr 19, 2009 | 09:40 PM
wcurtis's Avatar
wcurtis
2001 superduty 5.4
Old Apr 20, 2009 | 08:00 AM
projectSHO89's Avatar
projectSHO89
Follow the speed control's throttle cable. it goes from the throttle body to the servo.
Check the deactivator switch and the recall harness fuse. They're a pretty common failure.
Steve
