Stuck Sparkplug
Old Apr 19, 2009 | 04:19 PM
77F250Custom4spd's Avatar
77F250Custom4spd
Stuck Sparkplug
What can I do to get a sparkplug out that gets tighter as I try to loosen it?
Old Apr 19, 2009 | 04:51 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
Soak it in WD-40 and work it out a little at a time, backing it out and threading it back in a little bit to clear the threads. Hopefully it wasn't cross-threaded when it was put in.
What engine is it, anyway? And have you tried it hot and cold?
Old Apr 19, 2009 | 05:09 PM
Holiver31's Avatar
Holiver31
Run the engine for a couple minutes,,yeah you might burn yourself a little but it worked for me.
Old Apr 19, 2009 | 05:12 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
After it's out, use some anti seize compound on the new plug threads to help prevent this in future.
I had a 390 that liked to seize plugs as well.
Old Apr 19, 2009 | 06:39 PM
77F250Custom4spd
Its a 400. no I havent tried it hot.
Ill go and try again once it stops raining. Thank guys
Old Apr 19, 2009 | 08:21 PM
fmc400's Avatar
fmc400
MSEE
WD-40 is not a penetrating oil. Try PB Blaster.
Old Apr 19, 2009 | 10:29 PM
Jim1979's Avatar
Jim1979
x2 with the pb. you might want to use try heating it with a torch too if you can get at it withough burning anything else. I assume this is a head on an engine in the truck?
Old Apr 19, 2009 | 10:32 PM
shanes66charger's Avatar
shanes66charger
wd-40=water.
PB BLASTER!!!!!!
Old Apr 19, 2009 | 10:59 PM
highboy1975's Avatar
highboy1975
use the pb blaster. the in and out method works well too. treat it like a woman. you wana be gentle and not just force it. back and forth while applying the blaster will get you pretty far. let it soak a few days too with the pb, giving it a few squirts once a day or so.
Old Apr 20, 2009 | 04:03 PM
Bowtie_Schmowtie
WD-40 has always worked well for me- I don't care what anyone says. Of course, I've only been doing this for 20 years. And this is the only rusty one I've ever had.
Whichever aerosol you use, do be careful like highboy1975 said. If you get frustrated, put down the ratchet, spray it again and walk away. That's a lot easier than putting heli-coils in the plug hole after you've ruined the threads- or having to get a new head!
