Sponsored by: Auxito
speedometer
Old Apr 19, 2009 | 11:14 AM
mrplum's Avatar
mrplum
speedometer
2000f150 4x4 speedometer just quit won't move stuck on 70mph . Help please . Also codes 1717174 system to lean banks one&two is this o2sen?
Old Apr 20, 2009 | 09:26 AM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE mrplum! The speedometer is electronic and with that symptom, I would suspect it to be faulty. Before condemning it however I would unplug it from the truck and see if it remains stuck at 70 MPH.
No, you don't have bad O2 sensors with those DTCs. You have a vacuum leak. Check the air intake ductwork for leaks after the MAF sensor on to the throttle body. Good luck!
