Odd clutch chatter!
Old Nov 24, 2002 | 01:52 AM
Polkat's Avatar
Polkat
Odd clutch chatter!
The clutch on my '73 F-100 works fine and quite smooth if I let it out while the rpm's are near about 1500. Anything under that and it chatters enough to shake the truck. I've throughly checked all the usual things like all mounts, u-joints, read end, pedal adjustment, etc.and can find nothing. While the smoothness at the rpm's mentioned is quite odd, perhaps this is the usual indicator that it's time for a new clutch! Does everyone agree? Polkat
Old Nov 25, 2002 | 09:39 PM
jjcreasman's Avatar
jjcreasman
Odd clutch chatter!
from what you have described it sounds like the pressure plate is getting weak. A weak pressure plate will make the sounds you are hearing. good luck
Old Nov 25, 2002 | 10:22 PM
Mike W's Avatar
Mike W
Odd clutch chatter!
How old is the clutch? If you replace it, use a diaphram type.
Old Nov 26, 2002 | 08:29 AM
66stangfb's Avatar
66stangfb
Odd clutch chatter!
