OBD Scanner
Old Apr 19, 2009 | 01:07 AM
Rickx's Avatar
Rickx
OBD Scanner
I'm going to purchase a scanner and would like reccomendations. The vehicles I need to cover presently are:
2003 Excursion 7.3L
priorty # 1
2000 Jeep Wrangler 4.0L
Priorty #2
2008 BMW 535xi
just for fun
Thanks in advance.
Old Apr 19, 2009 | 01:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
If you only need something to show and clear codes then I would highly recommend a Scan Guage II. It does that and more.
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
Old Apr 19, 2009 | 11:12 AM
Rickx's Avatar
Rickx
What else could I use a scanner for?
Old Apr 19, 2009 | 01:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
You didn't click on the link??
Old Apr 19, 2009 | 08:31 PM
Rickx's Avatar
Rickx
Ok Ken, I did, but I didn't drill down in the website. I was on the fence of using a portable vs installed in a gauge pod. I'm back to portable (to deal with other vehcles). Where did you mount yours? I'm thinking velcro right on the dash in front of me. I appreciate the lead on this as it's cheaper than some others I've been looking at. After looking over the compatibilty list, this will work with my 7.3L PSD, right?
Old Apr 19, 2009 | 08:48 PM
Rickx's Avatar
Rickx
Ken,
Alright, now I have a question. Maybe OBDII for dummies. I could probably search for this but maybe you already know.
Is the OBDII conector going to output the same calculations for fuel such as MPG and miles to empty as the overhead displays? That thing is 4 MPG off. It's not a big deal. I can still do the math myself.
It will be a great help having a voltage meter.
Old Apr 19, 2009 | 08:54 PM
VaSheriff's Avatar
VaSheriff
I just bought this one.... very pleased with it.
http://www.jcwhitney.com/autoparts/P...hGroup?Ntt=obd
Old Apr 19, 2009 | 09:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by Rickx
Ken,
Do you currently run a chip or tuner?
It gets its calculations via the PCM just as the overhead does. However, you can "tailor" it by inputting amount of gallons used at fillup. After a few tanks its gets the correct average. useful for larger tires and such.
I use a small piece of Velco and mount it just to my left on top of the dash. It will work on any OBDII equipped vehicle gas or diesel. I use it in my Avalanche, Excursion and Mazda5.
Old Apr 19, 2009 | 09:49 PM
william_04_x's Avatar
william_04_x
I've had one of these for years now...They're great little tools..I'll display water, voltage, RPM, and IAT while on the road..
I put mine in the cubby next to the dash cup holders..
Old Apr 20, 2009 | 12:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
I like that LED! Where do you get things like that? Radio Shack? I'm a bit limited with store choices here.
Old Apr 20, 2009 | 08:07 AM
soutthpaw's Avatar
soutthpaw
The 7.3L Excursion is NOT OBDII compatible!!! This means that a standard OBDII scan tool will not work on the Ex... or any Ford Diesel!!! You need OBDII Enhanced software for that... Check out Auto Enginuity then you can click on the various brands on the bottom to see what the enhanced version will cover for each brand....
your other cars will give basic OBDII data but to get all the enhanced systems (anything not directly related to Emissions) you will need the enhanced version for that vehicle... There is really no cheap way to get an enhanced version scan tool... I also Have an OTC Genisys.
Keep in mind you will need to get the software upgrades to cover the year of your vehicles... German cars are also picky. Not sure off the top of my head but the BMW may be a CAN interface too... it depends how much stuff you want to do with the scan tool
The scan gauge II however is set up to read the PCM data even though its not OBDII compliant...
Old Apr 20, 2009 | 12:55 PM
rlh68050's Avatar
rlh68050
Correct!!
Auto Enginuity's Scan Tool does seem really nice. I have both the Snap On Modis and OTC Genisys tools and they too are great, but cost lots of $$$ (especially the Snap-On).
Old Apr 20, 2009 | 01:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
The 7.3L Excursion is NOT OBDII compatible!!! [SIZE=3]This means that a standard OBDII scan tool will not work on the Ex... or any Ford Diesel!!!
The V10 is the same way. I cannot get "enhanced" codes from the ScanGuageII.
Old Apr 20, 2009 | 04:23 PM
soutthpaw's Avatar
soutthpaw
The OBDII standard is regulated by Gross vehicle weight thats why many 3/4 and 1 ton vehicles don't need to be OBDII standard. I just got the Ford AE package but have not had time to play with it yet to really comment on it... though the AE package with the Ford, BMW and Chrysler enhancements may be your best bet... Call Clay at RIffRaff Diesel he is an AE dealer and I bet he can get you the best price around for what you are looking for.. he did for me...
Old Apr 20, 2009 | 04:31 PM
Rickx's Avatar
Rickx
Thanks for the heads up on the AE Package.
