So im driving on the freeway and my truck starts shaking really bad and i roll down my window thinking my tire is popped. It turns out all the tires are fine but there is like a popping sound coming from underneath my truck..
Any ideas??
Did you unlock your hubs? If you have shift on the fly, then maybe your hubs aren't unlocking.
konarain,
I answered your post in a different thread. I'll drop you a PM.
Any ideas??
It could be caused by any number of things, Terra. Low tire pressure (other than the popping sound), worn suspension components, ball joints, wheel bearing, steering damper, etc...you need to get the front end up on some stands - soon - and start shaking stuff around a little bit to track the problem down.
