brake master search
Old Apr 18, 2009 | 07:28 PM
primered's Avatar
primered
brake master search
HI.
I have tried a couple searches, but struck out. Has there been a thread discussing possible bolt-in m/c swaps for an early F-1?
Seems to me, I have read something about a mustang or galaxie m/c being an easy improvement...
Thanks.
Old Apr 18, 2009 | 10:47 PM
Julies Cool F1's Avatar
Julies Cool F1
I feel your pain. The new Search Engine is useless. I know there have been discussions on master cylinder swaps - most go with IFS threads or Disc Brake threads. You might try those. Also when you search, put "Master Cylinder" in Quotations Marks when you enter it. It helps sometimes.
Might try looking here:
https://www.ford-trucks.com/forums/5...der-on-f3.html
Good luck!
Old Apr 19, 2009 | 05:09 AM
primered's Avatar
primered
Thanks very much.
And I feel better about my search failures...
C
Old Apr 27, 2009 | 02:05 AM
1oldtimer's Avatar
1oldtimer
if it's anything like my '55 f100 you need the bracket from cpp (or others like mid fifty) and a mustang master. 1966 or 67 and older for drum/drum.
Old Apr 27, 2009 | 03:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thru 1966, ALL cars and trucks use a single master cylinder.
1967 and later: ALL cars and trucks use a dual master cylinder and a brake differential proportioning valve.
There are two different master cylinders for 1965/66 Mustangs. One was used with manual disc brakes, the other was used with manual or power drum brakes.
Power disc brakes were not available on 1965/66 Mustangs.
