white smoke, and other issues. ahh
whats going to cause white smoke? i just had the dang thing back at the shop and now it wants to put out white smoke. they charged me for a i think an ICP? i'd have to go get the ticket again. this is a 99 7.3L
they told me that the Hpop is leaking too. at the back were a big snap ring was, said i'd have to replace the hpop. not rebuildable he said. man im tired of hanfding out money on this thing.
also, to me it seems like the truck idles rough. i may take this damn tuner out and see if that clears anything up, i am not sure what type of tuner it is even, it was on the truck when i got it. has a little silver **** on the dash with 6 positions. previous owner said 50/75/100/140/stock.
has a small wire harness that goes down to the driver kick panel. goes into a computer box there.
I really want to keep the truck. i just got it but im getting aggrivated with it real quick. i have spent 1300 already, and now 200 on the icp? deal. I ain't sure if im getting the shaft or this truck is a damn lemon and everything is just slap wore out or what. 230K miles on the truck. They rebult the turbo, replaced the pedistall, repaired the upper Y pipe collectors from leaking. replaced one injector, tested the others.
AHH, im getting tired of spending the money for one thing after another. i'm thinking that the previous owners had not done a lick of maintenance.
I really should ahve done A LOT more research before buying a diesel.
Bump for you Howard...
sounds like the hpop is hard to get to eh? have to take the turbo and stuff off to get to it? seems like i read it was like in the valley, center of the motor up top?
yes they said they are stock injectors. they said they took them out and bench tested them, and found one not passing? so they replaced it. whats TS chip? i'll get a picture of it tomorrow.
i sure hadn't. i picked it up friday, drove it a little this weekend. but now that you mention that it did , to me, seem like the turbo sounded a little different too. i do smell oil. there was oil all over the engine when i got it back from them doing the topend stuff, turbo work and all.
This is the **** on the dash, and the wire harness going into the box at the kicker panel. how can it have 6 position switch and only have 3 wires?
Generally speaking, white smoke is an indicator of unburnt fuel. If you HPOP is going *****-up, it may not be injecting high enough oil psi to get a full stroke on the injector.
If it were me, I would get a scanner on it and watch my ICP and duty cycle. That will tell you alot about your HPOP and whether is toast.
I am thinking your best bet would be to hook up with one of the members that is close to you with an AE and some experience and have them take a look at it. I know that there are several FTE guys in Tennessee area...
