Straight six, please help identify
Old Apr 18, 2009 | 12:36 PM
zenmaster's Avatar
zenmaster
Hello folks,
I just bought a 1967 Mercury pickup with a straight six in it. It is not the original engine. I don't know how to tell if it's a 240 or a 300ci. What is the best way to tell? Here's a pic:
I can take more pics if needed.
Thanks for all your help!
John
Old Apr 18, 2009 | 12:51 PM
flipklos's Avatar
flipklos
The vin will tell you the original engine.
Its a 300 or 240 you are correct.
Crank is the best way to tell. However the head casting number may give you a easier ID. Thats not guarenteed though. People through 240 heads on 300s to raise compression. You want to know................Pull the oil pan.
Old Apr 18, 2009 | 01:11 PM
geezer43's Avatar
geezer43
Three groves in front pulley = 300 cu.
Two groves = 240.
Same block, different stroke, and a damn good engine
Jim Johnson
84 F150 short bed XL, I6, T18, 3.55 diff, 233k, one owner
Old Apr 18, 2009 | 01:19 PM
zenmaster's Avatar
zenmaster
Thanks flipklos,
The original engine, according to the vin was a 352. At some point it was replaced with the six.
I'll see if I can find a head casting number.
When (if) I drop the pan, what am I looking for? Crankshaft id number?
Thanks,
John
Old Apr 18, 2009 | 01:26 PM
zenmaster's Avatar
zenmaster
geezer, Guess it's a 240, yes?
Thanks!
Old Apr 18, 2009 | 01:29 PM
flipklos's Avatar
flipklos
Crankshaft ID # would be great. If I remember correctly its on one of the throws and visable. If not-3.98 is a 300 crank throw. 3.50 is a 240. A tape mesure and a buddy twisting the engine by hand will do it. Oh, discontect the coil, these engines are notoriously good starters.
Old Apr 18, 2009 | 01:33 PM
flipklos's Avatar
flipklos
My 300 has a two groove pulley. One for the alternator, one for the PS. 300 two groove dampener for a 1976. Had to argue with the parts guy to get it. Didint want to look for a two groove.
