Adding A/C to a '79
Old Apr 18, 2009 | 09:35 AM
shawnyboy's Avatar
shawnyboy
Adding A/C to a '79
Hey guys, I'm new to this site and love what I've been reading so far. Great info. Always loved the 1979 ford truck and now I'm looking to buy one, finally. The truck I'm looking at has a built 351 in which the ac components are removed. What kind of money am I looking at to totally put ac in this truck. It originally came with air so venting is already in the truck. Everything else I have to replace, compressor, evap, etc..
Any help is appreciated.
Thanks,
Shawnyboy
Old Apr 18, 2009 | 09:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
I'd look for a 1975/79 passenger car with a 351M or 400 and remove all the engine components from it.
There's far more cars around with A/C than 1977/79 F100/350's or 1978/79 Bronco's.
Take pictures of everything before you remove one part so you know how it all goes back together.
Make sure the A/C unit is intact without anything missiing or disconnected .
Once outside air gets into the compressor, dryer tank or condenser, the system must be evacuated within weeks, otherwise....these parts are history.
btw: EZ way to ID these two engines: 8 valve cover bolts per side.
Old Apr 19, 2009 | 12:04 AM
AerostarDad's Avatar
AerostarDad
Thanks,
Shawnyboy
Take it from a guy who had a '78 w Air....go with an aftermarket air system (Vintage Air, etc.) like street rods use,and hook up the outlets to your stock venting system. Aftermarket's have smaller, more efficient compressors and provide wayyyy better cooling than the 25-year old engineering stock stuff.
Good luck.
Old Apr 19, 2009 | 07:44 AM
73FOMO's Avatar
73FOMO
Hot Rod Air is another choice. Personally that's the system I will be installing when I get to that point. A complete system with Sanden compressor can be had for about $750. That's all that is holding me up....$$$.
Old Apr 19, 2009 | 11:30 AM
blackf-100's Avatar
blackf-100
Thanks,
Shawnyboy
I wished I had been on here earlier I just threw a complete ac unit away that came out of my 79 sorry
