Slave cylinder
Old Apr 18, 2009 | 08:13 AM
boschman36's Avatar
boschman36
Slave cylinder
What is involved in replacing the slave cylinder in a 86 f350 6.9idi 4 speed? I tried searching but I didn't come up with anything direct.
Old Apr 18, 2009 | 11:58 PM
Sycostang67's Avatar
Sycostang67
Remove roll pin, disconnect hose, dont lose the O-ring(just in case). Use a screwdriver or prybar to pop the old slave off and put the new one in it's place. Connect hose with new O-ring that should have come with the new slave. Install roll pin, and bleed the system. This is based on the assumption that you have an external slave cylinder like the BB fords do.
