slack in timing chain
Old Apr 18, 2009 | 03:00 AM
btorear's Avatar
btorear
Hello. I recently put a 351M in a 74 F100. Is there any way to check to see (or feel) if there is slack in my timing chain, without removing the water pump and timing cover? I once heard that i could remove the fuel pump and reach my fingers in to feel. wanted to check here first before wasting my time doing that. Any ideas? Thanks in advance for any help.
Old Apr 18, 2009 | 03:26 AM
lew52's Avatar
lew52
This is what i do . Take off dist cap & turn the crank with wrench & watch the rotor turn then turn the crank back the other way & see how far you have to turn the crank to get the rotor to turn . This should tell you how much slack you have .. Lew
Old Apr 18, 2009 | 06:14 AM
Mud Rat's Avatar
Mud Rat
If the the chain has never been changed, you can be sure it has streched and the cam gear is worn.
Old Apr 19, 2009 | 01:02 AM
johnboy427's Avatar
johnboy427
Pull the fuel pump and turn the crank just enough to get the slack on the drivers side and poke at it through the fuel pump hole, its a pretty strait shot. Turn counter clockwise when standing in front of the truck, you have to do this because one side of the chain is always tight unless it is broken. This is a lot easier if you don't have power steering.
-Johnboy
Old Apr 20, 2009 | 09:54 AM
btorear's Avatar
btorear
Using the method of removing the distributor and watching the rotor turn while turning the crank by hand....How do I know how much slack is too much? Any ideas?
Old Apr 20, 2009 | 11:37 AM
lew52's Avatar
lew52
...Well as soon as you start to turn it back the rotor should turn if theres no slack...The farther you turn it with out the rotor moving the more slack you have . See what happens ... Lew
Old May 1, 2009 | 02:49 PM
mustang81's Avatar
mustang81
If you have more than 50,000 miles, don't bother checking, replace them.
Once the cover is remove turn the crankshaft to tighten one side of chain and mesure slack side with a straight edge on the 2 gears. if it deflects more than 1/2 inch, replace it.
Go with a straight up timing chain - 0 degree
