Vacuum leaks
Old Apr 17, 2009 | 10:26 PM
inline4.9beast's Avatar
inline4.9beast
Vacuum leaks
I have a problem in park and neutral with high idle problems, and suggestions?
Old Apr 18, 2009 | 09:22 AM
Lazy K's Avatar
Lazy K
Best way to find vacuum leaks is to spray some carb cleaner around the manifold and vacuum pipes while listening for a change in engine note.
You should also consider cleaning the Idle Air Control valve on the throttle body. Go to fordfuelinjection.com for how to.
