Is there some trick of the trade for removing an EGR valve? I need to replace mine, but when trying to take it off, it was so tight it felt like I was going to wring the whole thing off? Any suggestions?
I assume that you are talking about the hard line going to the EGR valve from the exhaust manifold? I used a MAPP gas torch (a propane one will work, just take longer) and I heated the flare nut for a while, then sprayed it down with lots of WD-40 until it stopped smoking. Then it broke free with no problem. Ditto for the other end at the exhaust manifold.
Yes, that's what I'm talking about. I haven't tried heat but I will. Thanks.
heat will probably work, i've been soaking mine with blaster everyday trying to get it loose but no results yet, I don't have a torch but may barrow one soon
The key is to shock it by heating it up then quenching it with WD-40. I love PB but not for this type of operation, as the solvents in PB prevent it from penetrating under heat as well as WD-40 IMHO. PB will work, but more of it vaporizes than actually sinks in. As a last resort, if the WD-40 doesn't work, heat the hell out of it then douse it with some synthetic motor oil. That stuff loves to creep in the heat. Use the thinnest stuff you can (0W-20 is best).
