fender year range?
Old Apr 16, 2009 | 01:27 PM
Stephen67's Avatar
Stephen67
fender year range?
I'm looking for a set of fenders for my '56, I know 53-56 will work, but did Ford change the fender design in '57? If not when did they?
I plan on modifying them quite a bit, they would be way too small stock on my 600.
Old Apr 16, 2009 | 01:48 PM
Fomoko1's Avatar
Fomoko1
The 57 Ford truck fender is totally different.
Old Apr 16, 2009 | 01:50 PM
Stephen67's Avatar
Stephen67
Thank you, just what I needed to know.
Old Apr 16, 2009 | 01:54 PM
Fomoko1's Avatar
Fomoko1
Around here the 57-60 fenders rust as bad and as fast as the 53-6.
Old Apr 16, 2009 | 03:26 PM
mossyoak1992's Avatar
mossyoak1992
i think you are talking about the rears and i think the rears are the same from 53-72
Old Apr 16, 2009 | 03:30 PM
Fomoko1's Avatar
Fomoko1
My bad.
I was only thinking about fronts, John is right in that the rears would interchange in these years.
Old Apr 16, 2009 | 03:32 PM
fatfords's Avatar
fatfords
This is true, except that the 57-72 have the holes to mount the running boards about 2 inches higher. Easy fix if the rest is in good shape.
Good Luck!
Old Apr 16, 2009 | 04:25 PM
Stephen67's Avatar
Stephen67
Ah thanks, I thought they looked the same... should have mentioned I was talking about the rear.
They're going to be heavily modified anyways, so the holes for the running boards won't be a problem, heck those have to be custom too.
POS-F500
Feb 10, 2013 08:13 PM
MrMagoo187
Feb 25, 2011 01:45 AM
J2Davis
Dec 2, 2003 09:09 AM
denisontexas
Aug 13, 2003 06:44 PM
Bushwacker
Jul 14, 2000 08:09 AM
