Sponsored by: Real Truck
Cop's
Old Apr 15, 2009 | 09:58 PM
onephinesuperduty's Avatar
onephinesuperduty
Cop's
What do you all think of the aftermarket COPs available on ebay. 89 for 8 compared to 339 for 8 motorcraft brand is a big difference...any input?
Old Apr 15, 2009 | 11:14 PM
Chaosracing's Avatar
Chaosracing
I have heard to many bad things about those COP's. I would go to NAPA, National Auto, Advanced Auto, etc and get them thru one of those places. I got one at National Auto in December and it was around $30.00
Old Apr 16, 2009 | 06:54 AM
RFD_Truckie's Avatar
RFD_Truckie
Whats a COP? I am still learning the abbreviations....
thanks
Old Apr 16, 2009 | 07:09 AM
smithrngr's Avatar
smithrngr
coil on plug is what cop is.
Old Apr 16, 2009 | 08:28 AM
Stone Mathews's Avatar
Stone Mathews
NAPA sells an Echlin brand COP. Seems to work great. No issues so far anyway.
Stone
Old Apr 16, 2009 | 09:28 AM
DetailerDave's Avatar
DetailerDave
I have gotten 2 at Pep Boys, so far. One has been on the truck now for over 2 years with no issues. Cost, I think, was around $37 with the boot attached.
Old Apr 16, 2009 | 11:01 AM
RACERX7775's Avatar
RACERX7775
I got a set of 10 accel COP's for $220. brand new. EBAY is my friend. They have been flawless. Now its time to change the plugs....
Old Apr 16, 2009 | 11:08 AM
eightrac's Avatar
eightrac
Good luck with those Accel COPs when you finish your plug install, thats when they usually cause the trouble.
Echlin is the best I've been able to find. Even the exterior construction looks superior to even the stock pieces.
Old Apr 16, 2009 | 12:07 PM
onephinesuperduty
perhaps a more suitable question would be do you all think COP's are my problem. All new filters etc, still a misfire in it unless i really get on it hard. Misfire is only when im going up hills at lower rpms. Kind of at a loss on this one and hate to dump all this money into cops if its indeed not them. thanks again!
Old Apr 16, 2009 | 12:18 PM
orng1's Avatar
orng1
That does sound like an ignition misfire.
Old Apr 16, 2009 | 01:18 PM
smithrngr's Avatar
smithrngr
my truck did the same thing when i was on it light about 2 grand or so, i hooked up to my scanner and had a #7 miss fire replaced the coil and all was fine.my scanner is a cheap advance auto on around 100 bucks and still told me what one it was. if you have a friend with a scanner i would throw it on there and see what you get.
Old Apr 16, 2009 | 03:37 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
By the way, for those of you who only need to replace a defective coil,
our SOS Coils are available separately.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Apr 16, 2009 | 07:46 PM
RFD_Truckie
Thanks. I will get these abbreviations one day..
Old Apr 17, 2009 | 09:23 AM
eightrac's Avatar
eightrac
"Performance" COPs net you nothing. The stock coils put out more voltage than the plugs will ever need. What I do when I encounter a misfire is first, check the boots. If even one looks at all spongy, replace them all. $12 shipped on ebay. Next, buy one COP and replace #1 COP with the new one. If it doesn't cure it, take the known "good" coil you removed from #1 and move it to #2... And so on, until the misfire goes away. If this doesn't work, and I have had this happen before, change the plugs. I had one go bad once before and you couldn't tell it was bad by looking at it. I say to try an new COP first because one COP is cheaper than 10 spark plugs for a V10.
Old Apr 17, 2009 | 10:12 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
A lot easier to just have the codes pulled and change the bad one the first time!!! A code can be (and will be) set without turning on the CEL. Code reader has been a part of my tool inventory for a very long time now....Lots easier than running to AZ everytime.
