rearend
Old Dec 6, 2002 | 06:19 AM
DerFroggy's Avatar
DerFroggy
rearend
I have a 96 F150 1/2 ton 2 wheel drive pu. 300 straight with 5 speed manual trans. Axle code is 18 on the door jam. The dif cover is 10 bolt with the pattern being--- 3 across the bottom, in a smile pattern. 3 across the top in a frown pattern. 2 on each side. Measured it as best I could, between say, 10 1/2-11 inches wide. I am going to have a powertrax noslip put in but have been reading horror stories about the noslip. Wanted to be sure I ordered the right one the first time. Is it 30 or 31 spline? One web site said 30 spline. Is 18 the code for LSD or open? Is it 3/4 or 7/8 inch shaft? I guess its a Ford 8.8 or is it a Dana? And lastly, why in the hell am I having such a hard time figuring this out? This is my first Ford, always had the ones that begin with a C. Thanks guys
Old Dec 6, 2002 | 01:17 PM
95F1504x4offroad's Avatar
95F1504x4offroad
rearend
Its probably a Ford 8.8" diff with 31 spline axles. Ford also used this diff in cars with 28 spline axles.:-X12
Old Dec 6, 2002 | 03:45 PM
captntim's Avatar
captntim
rearend
yep....its an 8.8" and the axle code 18 means you have an open (as opposed to limited slip, locked, etc.) rear end with 3.08 gears.
captntim
1994 F150 4x4 supercab open 3.55s
stock EFI 302 mated to an A4OD
Old Dec 6, 2002 | 09:58 PM
MustangGT221's Avatar
MustangGT221
rearend
What are you going to be doing with the truck? You can get a factory LS unit for cheap and install it. The factory unit is good, I got one off of ebay for $50 bucks! You can get a rebuild kit for $75 bucks to make it like brand new. Make sure it is 31 spline as there are a lot of mustang 28 spline LS's on ebay. It's very easy to do the swap, I will be writing an article on how to do it shortly.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 7, 2002 | 12:44 PM
cek181's Avatar
cek181
rearend
[updated:LAST EDITED ON 07-Dec-02 AT 01:59 PM (EST)]oh im confused now. i got axle code 18 on my door. and the tag on the differential says 3.31. my ford dealer tells me that 3.31 was never put in f150s around the 95 model year, even tho they don't ever know that much. somebody save me
chris
Old Dec 7, 2002 | 02:20 PM
steve83's Avatar
steve83
rearend
[updated:LAST EDITED ON 07-Dec-02 AT 03:23 PM (EST)]Did you buy the truck new? Has the rear end ever been rebuilt? Was it swapped in from another vehicle? Have you ever tried to measure the ratio by rolling the tires and watching the driveshaft? With a penlight, you might be able to read the gearset codes off the edge of the ring gear by looking thru the diff fill plug hole. It will either have the ratio or the 2 numbers of teeth on the 2 gears stamped into the edge of the ring gear near the "Ford" oval. According to http://www.drivetrain.com , your ring gear is PN F3UZ4209A and the numbers of teeth are 43R & 13P to make a 3.31 ratio.
Old Dec 8, 2002 | 10:05 AM
cek181's Avatar
cek181
rearend
steve, when i go home ill have to try that. the tag on the diff i am assuming is factory. i took it in to the dealer in my town and he didn't believe it. i donno. ill just runner the way she is till i get my d44 straight and 9 inch with 4.56s and lockers and ill be good to go
chris
Old Dec 8, 2002 | 01:33 PM
mpb_27's Avatar
mpb_27
rearend
95bigbronco
1978 - 1996 Big Bronco
26
Jan 9, 2012 06:02 PM
ekuhn
1983 - 2012 Ranger & B-Series
Dec 25, 2010 09:58 AM
Uglyhat
Jan 21, 2006 01:12 AM
pdrhodes1
May 5, 2005 12:33 PM
