ac shim problem
Old Apr 15, 2009 | 12:24 PM
rkorzeb's Avatar
rkorzeb
ac shim problem
About 2 months ago i replaced my A/C clutch. i shimmed it out about 4thousands and it cycled on and off fine. last week i went to use my ac for the first time since and it didn't work.the clutch is staying disengaged. i took the shims out and tried it and the clutch stayed engaged and never cycled off. i tried the smallest shim in the kit and the clutch just barely spun like about a quarter of the way around and stopped. any help troubleshooting problem?
Old Apr 17, 2009 | 09:28 AM
rkorzeb's Avatar
rkorzeb
sorry i made a mistake it was 40 thousandths not 4 thousandths. if it helps i have a 99 f150 with a 5.4
Old Apr 21, 2009 | 08:52 PM
HomerWinzlow's Avatar
HomerWinzlow
Im not sure without seeing it first hand. But most clutches on the Ford dont fail. If the clutch failed it is usually because the bearings in the compressor failed and the gap closed to the point that it burned up the clutch. In this case you need a compressor and filter flush of the system, accumulator, orifice, and new orings with system recharge.
Compressor gap should be around 20 thousandths.
Welcome to FTE
Old Apr 21, 2009 | 11:52 PM
lsrx101's Avatar
lsrx101
Yep. What Homer said.
A common business card makes a good go-no go feeler gauge. If it falls into the gap, it's too wide.
Old Apr 22, 2009 | 11:06 AM
rkorzeb's Avatar
rkorzeb
I change the clutch because the bearing in the pullley was shot. the clutch was engaging and disengaging fine just the pulley was grinding.
Old Apr 26, 2009 | 06:00 PM
projectSHO89's Avatar
projectSHO89
What brand part did you use and where did you buy it?
Old Apr 26, 2009 | 06:42 PM
rkorzeb's Avatar
rkorzeb
i think it was compressor works. i bought it at auto zone.
Old Apr 27, 2009 | 07:11 AM
projectSHO89
Thought so. Take it back and order a Motorcraft instead.
I bought one of those and found that the length of the snout was wrong and it did exactly as you described. Unfortunately, I lost the receipt so I got screwed out of $35.
Bought my Motorcraft from RockAuto.
Old Apr 27, 2009 | 08:50 AM
rkorzeb's Avatar
rkorzeb
was it to long or short? i thought that the shims were supossed to solve that problem
