Robert, sent couple of pic's on info requested, sorry looks like 1 did not take, kinda in a hurry and out the door but I can download others if need more.
a light staying on typically means a bulb is burned out...the fuses are glass tube fuses like all cars of the 60s, and there are none under the hood at all...all are at the dimmer light sw. on the firewall...as far as the lights go...
anyone have a photo of the fuse box and its location?
I find it hard to believe mine is correct, a couple of boxes combined, and on the inner fender completely exposed to water and oil from the engine compartment - is there a cover for it?
fuse box is located on the firewall right above the foot dimmer switch...far left side....its a small squareish box...theres 7 fuses total I believe in that box...Check emailll I will resend the wiring diagrams.....
- cs65
CHECK email again...there is NO fuse boxes on the inner fenders of these trucks at all originally...someone added alot of stuff at one point it sounds like...
Reason: added info
