1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Front Drive shaft turning
Old 04-15-2009, 07:55 AM
grey1169's Avatar
grey1169
grey1169 is offline
Hello!
I was troubleshooting a grinding/rubbing noise in the front of my 97 Expy the other day. Discovered that the cat heat shield had been rubbing against the front drive line.
I had the truck up on 4 jack stands and in 2WD. I would have thought that this shaft would not turn unless the 4WD was engaged. I do that the A4WD option in this but the switch is set to 2WD.
The front wheels are not moving when on the jack stands but the front drive line is.
I called Ford and the stated that this is normal. Not sure if I agree with them.
Any thoughts?
Old 04-15-2009, 09:38 AM
alloro's Avatar
alloro
alloro is offline
Received 4,243 Likes on 2,474 Posts
Is it turning only because there's no load on it, or is it actually locked to the transfer case and getting full power? If you're in 2H the front driveshaft should not be getting powered. The fluid in the TC could be causing enough drag between the clutch plates to turn the driveshaft. If that is what's happening you should be able to hold it from turning.
A while back on my 97 I would get a squeaking noise (sounded like crickets) when I was in A4WD or 4WD, but not when I was in 2H. The noise turned out to be the front driveshaft u-joints. So that alone tells me the front driveshaft was not turning in 2H, or at least it wasn't turning fast.
'02 Excursion Guy
05-24-2017 07:14 PM
Jack Peterson
05-07-2016 06:39 PM
Misterunlimited
1997 - 2003 F150
10-01-2015 12:54 PM
builttoughf350
1999 to 2016 Super Duty
06-01-2010 10:16 PM
ssharber
39
09-19-2009 09:30 PM
Quick Reply: Front Drive shaft turning
