head gasket recomemdation
Old Apr 14, 2009 | 09:59 PM
4x250cx's Avatar
4x250cx
looks like im headed for a head gasket job. dealer has agreed to any after market parts. arp head studs, but what about the gaskets any recomdations???? not looking to hot rod just looking for reliability and mabe a mild tune. truck is pretty much stock execpt exhaust@guages, thanks for your input, 04 6.0
Old Apr 14, 2009 | 10:07 PM
brickie's Avatar
brickie
Stock will do all what you require no trouble.
Old Apr 14, 2009 | 10:08 PM
adambomb's Avatar
adambomb
sounds like all you need is STOCK FORD HG kit... They are said to hold atleast 500hp if the ARP are torqued correctly and the heads are flat. make sure to ask the dealership to check the head flatness or if the heads are cracked. my truck was stock at one time and the HG's blew and both heads were found to be cracked so it does happen. Good Luck!
Old Apr 14, 2009 | 10:16 PM
4x250cx's Avatar
4x250cx
thanks
thanks you guys for the come back but what about these wire ring things ect if its gettin done i want to get it done right and long,thanks
Old Apr 14, 2009 | 11:37 PM
powerstroke72's Avatar
powerstroke72
If I'm not mistaken, those are a real PITA to use and have to applied absolutely perfectly or they'll fail. There's been much discussion about the Hypermax gaskets and unless you're planning on more than about 550 horsepower, the stock will do fine.
Old Apr 14, 2009 | 11:49 PM
cerroneseuropean's Avatar
cerroneseuropean
06 F250sd 4x4 6.0 for sale
Hello Guys Vin #1FTSW21PX6EC81086 asking 32,000.00
2006 Superduty 6.0 Powerstroke,45,000 miles extended warranty to 100k miles,Very Clean truck Owned By Mechanic,All the goodies 4"Donahoe racing Lift with Dual Sterring Stabilzer,H/D rear air springs,37x13.50x18 Pro Comp XTreme A/T Tires,Pro Comp Xtreme
Alloy Wheels,Edge Power Programmer With Piller Pod (Not Currently on Truck)Bushwacker Painted Wheel Fender Flares.This Truck is very clean Color Dark Shadow Gray Clearcoat/Int Medium Flint Leather Call Frank cell (510)381-0948 Vin #1FTSW21PX6EC81086 (650)365-4145
I am Sorry I will try to move it now!!
Last edited by cerroneseuropean; Apr 14, 2009 at 11:59 PM. Reason: I think I posted in the wrong place Sorry can you repost
Old Apr 14, 2009 | 11:58 PM
powerstroke72
You need to move this to the classified section per FTE guidelines. You can't advertise items for sale in the general forums:
https://www.ford-trucks.com/guidelines.html
Old Apr 14, 2009 | 11:59 PM
powerstroke72
duplicate post
Old Apr 15, 2009 | 09:51 AM
4x250cx's Avatar
4x250cx
thanks for the input
