Sponsored by: Auxito
Tranny Problems
Old Apr 14, 2009 | 08:27 PM
delldude's Avatar
delldude
Angry Tranny Problems
When i started home this evening when i got up to 45mph and started up a hill the tk acted like the transmission is slipping. When it does it i can hear the truck RPMS go up. So the next hill i come up too i took the truck out of overdrive and it didnt do it. Stuck the truck back in overdrive and the next hill it did it agian. Any information would be greatful.
Old Apr 15, 2009 | 06:20 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
I know this may sound insulting, but check your fluid level.
Old Apr 15, 2009 | 07:59 AM
l-m tech's Avatar
l-m tech
sounds like the od band is slipping.does the fluid smell burnt
Old Apr 15, 2009 | 08:13 AM
BLK94F150's Avatar
BLK94F150
Is it doing it right at or right around 45MPH when the torque converter locks? Maybe more when there's a load on it. First check to see if you have the 4R70W. Most F150s do. Over time many develop the dreaded torque converter shudder. How many miles and how often is the fluid changed?
In any case a complete drain/refill is in order with Mercon V. Often that fixes the problem.
Mike
Old Apr 15, 2009 | 09:22 AM
delldude's Avatar
delldude
I checked the fluid level its dead on it. The fluid smells fine. I just had a torque convertor put in 3weeks ago and a shift solenoid put in about a week and a half ago cause the torque convertor locked up. With brand new fluid and filter. Any suggestions. Its exactly when you get up to 45mph. The truck starts shaking when it does it and its when u are starting up a hill or incline when the truck starts getting a load.. Is it the torque convertor locking up again.
Old Apr 15, 2009 | 09:26 AM
BLK94F150's Avatar
BLK94F150
What I'm talking about is torque converter shudder during normal lockup. When in OD the torque converter will lock up to be like a manual transmission. I don't know what happened to it previously, but the TC locks up normally.
Is the shaking brief, like hitting a rumble strip or is it continuous?
Mike
Old Apr 15, 2009 | 10:15 AM
delldude's Avatar
delldude
It is like you said running across a rumble strip. It will do it untill you get back into the gas or untill it drops back down a gear. If you take it out of over drive it doesnt do it at all.
Old Apr 15, 2009 | 06:42 PM
01sport150's Avatar
01sport150
could you have a misfire from a bad COP causing the shudder
Old Apr 15, 2009 | 07:05 PM
BLK94F150's Avatar
BLK94F150
Does it do it constantly or just for a second or two then all is well?
TC shudder is just a second or two like if you just hit a rumble strip for a second. If not, you might have a miss fire like was stated. If you did just have transmission work done, I'd take it to them.
Mike
Old Apr 15, 2009 | 07:53 PM
delldude's Avatar
delldude
I took it back to transmission shop. They said they would let me know in the mourning. If its not that and they say everything is fine what should i look for next. I just did a tune up on the truck.
Old Apr 15, 2009 | 08:31 PM
BLK94F150's Avatar
BLK94F150
Have the codes pulled (Autozone can do it) and post them here. We'll need the actual code. What plugs did you use? Did you use dielectric grease? Did you replace any coils or boots?
The codes will be a big help. Also what year and engine.
Mike
Old Apr 16, 2009 | 07:48 AM
delldude's Avatar
delldude
The truck is a 2002 Ford F-150XL 4.6L triton SOHC. I put brand new Motorcraft Platinums in truck gapped at .045 thousands. i didnt put the dieelectric grease. When i get the truck back i will pull the boots off and put that on. How important is that dieelectric grease on there. How often does the boots need changed they all look good when i pulled them off. I cleaned them and everything.
Old Apr 16, 2009 | 05:41 PM
BLK94F150's Avatar
BLK94F150
Dielectric is pretty important. First have the codes pulled.
Mike
Old Apr 16, 2009 | 08:49 PM
delldude's Avatar
delldude
Okay got it back from transmission shop. They cant get it to make it shutter. Drove home and drove fine. Took it by and got it hooked up to the computer thing. No codes. So i drove home and pulled the cops back off and made sure everything looked clean and put that dielectric grease on the Boots and WOW what a difference. The truck idled better and everything. Took it down road and no shutter or nothing at all. Could i just had a bad connection??? Anyway its doing good so far. I will know more after i drive tomorrow cause i got alot of running to do. Thanks everyone for the information so far. This site is the BEST.
