Wheels
Old Apr 14, 2009 | 08:26 PM
SmallBlockV8's Avatar
SmallBlockV8
Wheels
I have a 1982 f250 and I was looking for a set of wheels. Ifound a set off a 2003 f250 and I was wondering if those wheels will work on my truck.
Thanks, Brendan
Old Apr 14, 2009 | 09:13 PM
forum155pl's Avatar
forum155pl
98 and up are 8 x 170mm and yours are 8 x 6.5 inches.
They will not fit. Up to 97 will work
beat ya to it stosh!
Old Apr 14, 2009 | 09:16 PM
hittman1422's Avatar
hittman1422
i think the bolt pattern is different, but the pattern on your 82 should be 5x5.5
which means five lugs 5.5 across from eachother(correct me if i'm wrong)
here this might help
https://www.ford-trucks.com/forums/7...g-pattern.html
good luck
Old Apr 14, 2009 | 09:22 PM
displacement4me's Avatar
displacement4me
Its for a 250 - he has 8 lugs
Old Apr 14, 2009 | 09:31 PM
forum155pl's Avatar
forum155pl
wow good point!,, i retract my reply, i have no idea!
Old Apr 14, 2009 | 09:34 PM
uncle.stosh's Avatar
uncle.stosh
They will not fit. Up to 97 will work.
Old Apr 14, 2009 | 09:53 PM
hittman1422
well we KINDA beat stosh to it..... not really though....
no offense stosh but you're the man to beat!
Old Apr 15, 2009 | 07:02 AM
uncle.stosh
Good thing for the 5 minute edit, huh?
Old Apr 15, 2009 | 03:19 PM
HappyGA's Avatar
HappyGA
If you are looking for wheels like that, look for them of of a Dodge Ram 2500. They are still 8-6.5" Bolt Circle. That is what is on my 2003 dodge Ram 2500 in the pic below. It has the Cummins Diesel.
Old Apr 15, 2009 | 03:38 PM
86bigred's Avatar
86bigred
but if you go with the dodge rims make sure the hub centers will fit.stosh would know this one to.
Old Apr 15, 2009 | 05:21 PM
uncle.stosh
Ford and Dodge both use the large centers and are interchangeable.
Chevys use a smaller bore center and will not fit (most of the time).
Old Apr 15, 2009 | 08:02 PM
SmallBlockV8
Wheels on f250's
So the 2003 wheels won't work, or will they? It is a light duty truck so the size of the hole in the center doesn't matter. So are the lugs the same distance apart where the bolts will line up and fit?
Old Apr 15, 2009 | 08:29 PM
uncle.stosh
Did you bother to read my post(s)?
Your question was already answered.
