2.5L questions
Old 12-21-2009, 09:53 AM
Joel59's Avatar
Joel59
Joel59 is offline
2.5L questions
Hello. I have a 98 ranger with the 2.5 four cylinder. The timing belt broke on it this weekend. I pulled in apart and installed a new one. I triple checked the timing marks and am sure that all three line up as they should. While I had it apart, I decided to put on new spark plugs and wires. I pulled off the intake manifold and removed the vacuum lines to get at the two difficult spark plugs. After I got all finished my ranger started right up and idled well. I thought all was fixed. When I put the truck in reverse it died. Then it didn't want to start up again. I had to pump the gas to get it started again. It acts like it is loading up with fuel, as it seems like the exhaust smells like raw fuel. I also notice that the farthest fuel injector back is ticking loudly. Did I screw something up with the injector? It seems more like a fuel problem than the timing. The timing is on. What are your thoughts? Thanks.
<!-- / message -->
<!-- controls -->
Adamtgarner
1983 - 2012 Ranger & B-Series
06-17-2016 07:02 AM
djohnton89
21
06-04-2016 05:54 AM
WhiteBeast-05-powers
02-22-2016 09:29 AM
19tanker
26
09-08-2014 03:10 AM
98Ranger2.5
4 Cylinder Engines
10-19-2007 06:54 AM
Quick Reply: 2.5L questions
