Aftermarket Products
Sponsored by: Worksport
Additives
Old Apr 14, 2009 | 06:35 PM
mtntop1's Avatar
mtntop1
Additives
Here is a question for all of you,are after market gasoline additives and fuel injector cleaners that you add pour in your gas tank any good or should I just use a name brand gas.
Old Apr 14, 2009 | 08:07 PM
4DTech's Avatar
4DTech
Depends on Gas or Diesel.. The motorcraft line of products works really good the Cetane Booster, and Anti-Gel additives work really well. Alot of happy cust. with that. As far as gasoline run higher octane once in a while, (Full tank of super), change your fuel filter every 30K miles you shouldn't need additives... I run reg. in my truck but every 3-4 fill-ups I run super and have no issues...
Old Apr 15, 2009 | 01:34 AM
dirtballer's Avatar
dirtballer
I run stp gas treatment about once a month can't really tell if it is working or not but i get around 20mpg on the freeway and about 16 to 18 mpg around town
Old Apr 15, 2009 | 10:50 AM
Beechkid's Avatar
Beechkid
I use (since 1970's) Marvel Mystery Oil- 1 oz per gallon for either long term storage or fuel system cleanliness
Old Apr 15, 2009 | 07:52 PM
ReAX's Avatar
ReAX
Something to keep in mind is higher octane fuels burn cooler. The thermal expansion is a part of what makes the piston go up and down. Running a cooler burning fuel allows you to advance the timing a little bit. I'm not sure how it effects the fuels stoich, but running octane boosters or high octane fuel without tuning, it's not going to do a whole lot for you.
With 93 octane and tuning, I do get slightly better mileage.
Old Apr 17, 2009 | 05:42 AM
rsylvstr's Avatar
rsylvstr
when i used to hang out on the bobistheoilguy site, the "chemists" said that Chevron Techron additive had a high amount of PEA's (poly ether amines) and that stuff works....i've used it in the past when i found the twofer sale at AAP
