OK so i robbed the cab lights off a semi for my 93 f250. Ive tested them and they all work. Now i have them installed i just need to finish wiring them in. I robbed a switch out of another semi, because i want these to be a seperate circuit from everything. Now I have a 20 amp switch and i was wondering how big of a fuse i would need for those 5 lights? I reckon a 10 amp fuse would do it? If not i guess i could always just put in a bigger fuse.
I think 10 would be fine might not even need that many for just cab lights they are low watage so dont pull to many amps as long as you wire them in parallel.
Duh you have to wire them in in parrallel they ground threw the housing
Reason: I a dumb @&$
Thanks for the welcome. These ones dont ground through the housing. Plastic dont work so good for that lol. They have a wire for it. Luckily i nabbed the harness out of the semi.
Oh ok most bolt on lights have a metal srtip where the head of the bolt gose for the ground. If you ohm out one of the lights and tell me the resistance and howmany lights you are mounting I can tell you aproximatly howmany amps it will draw.
If you use 5 lights wich I think is the norm for the clearance lights a 5 amp fuse will be pleanty. I'm boared so i used the amps to find the home then did the math of resistance of the parrallel circute and used max exceptable resistance of wireing slices and a switch to come up with it I need a life
