Same old speedo question, with a twist!
This question has been asked before, by many, including myself.
I have an 03 SD which has an inop speedo (auto door lock function inop as well). I've done the basics,like chasing down wiring, checking connectors, including replacing the VSS, which did nothing. So I pretty much moved on to other issues more important to me. But this has always bugged me...
There is one twist to this that perhaps may bring in a new idea from some of you. I do notice, that sometimes, if I leave the truck out in the weather overnight, and it rains, or has been wet out, the next time I use the truck the speedo starts working again for a while. Thinking about this, I am wondering if perhaps this may be hinting at a grounding problem somewhere. Thinking is that when wet, I get a ground somewhere, causing things to work for a bit... Am I all wet with this thinking ? (pun intended). And if this may be right, I have no idea where to look for the bad ground within that circuit.. Any ideas from anyone that may be able to help me finally kill this problem would be most appreciated.
Thanks
Rich
I remember reading somewhere that there is a ground lead in the engine compartment that guys have talked about checking...sounds like it's happened to more than one or two guys.
I'm not a mech so let's wait till the experts jump on here this PM and let them advise you!
Joe
Short of having a dealers proffesional mechanic with the correct information and know how look at it, you are subject to finding the problem yourself. Always look at the most obvious areas first.
Good luck
